miguel
Post by miguel on Dec 20, 2008 17:04:30 GMT
How can I remove the lock on the boot handle? Just dont want to force anything and I need to send it for chroming. Thanks Miguel
Post by Kev on Dec 20, 2008 17:43:00 GMT
I think if i remember correctly that the lock barrel is held in with a small pin. You will need to drive out the pin then use the key to remove the barrel.
Good Luck, Big Kev.
Post by johnwp5bcoupe on Dec 20, 2008 18:37:10 GMT
Spot on Big Kev when you come to re-assemble Miguel the square bar has a long side and a short! also don't force the lock as the pin on the back of the barrel easily breaks off
