Allan NZ P5b
1971 p5b Auckland New Zealand
Post by Allan NZ P5b on Jan 15, 2009 10:39:42 GMT
Last week the indicator started playing up. Occasionally the right hand one would not work Today on the way to work the right hand one stopped and the left hand one became intermittent. On the way home they both stooped and smoke started to come out from behind the shroud as I pulled into my drive. Pulled shroud off and looked at switch smell of burnt Bakelite removed switch from loom and car and took inside. cleaned and carefully disassembled.
It was very worn and the spring loaded contact that slides in a nylon slot was badly pitted so over heated melted its nylon slider, slid out of place and caused a short and the short had caused the nylon to melt further. Used some resin and rebuilt the nylon slider and cleaned up contacts. But not to confident even though now back in car and seems fine would like to source a replacement ideally a good one as car is my daily driver.
Does any body know of any other vehicle with the same switch that may be easier to find in NZ
Any suggestions?
Thanks in advance
Post by johnwp5bcoupe on Jan 15, 2009 10:58:43 GMT
I would have a word with David Green Allan with postage I wouldn't have thought it would be too expensive and not worthwhile trying to find a substitute I would check the indicator unit Allan? plus I would have thought the 15amp fuse should have gone
Post by dorsetflyer on Jan 15, 2009 15:50:46 GMT
I believe JRW does a refurb kit for the indicator switch. Might be worth giving him a ring or e-mail him Allan.
Post by Phil Nottingham on Jan 15, 2009 16:44:41 GMT
There are no equivalents - there are even 2 different versions for 3 Litres. However most British cars of the late 1950 and into early 1970's used a very similar type of Lucas switch eg Morris Oxfords and perhaps some bits are interchangeable
Post by Warwick on Jan 16, 2009 5:37:17 GMT
Allan,
Why not use some little relays and take all the load off the switch. That would also allow you to replace the wiring to the switch with new, flexible, light-gauge wire while you have it apart.
Post by Phil Nottingham on Jan 16, 2009 19:37:00 GMT
A secondhand one has just gone for a copule of £'s on Ebay - not much use for NZ though
