Post by seacutter on Jan 17, 2009 15:48:31 GMT
Hi, Can anyone tell me the highest ratio diff or complete axle that it is possible to fit to a P5? (Fitting a 2.7 Nissan diesel engine with auto box).
Post by johnwp5bcoupe on Jan 17, 2009 16:00:46 GMT
Various ratio's used through the evolution 3.9 Mk1 1A II,3.54 Mk3 auto P5 P5b,4.3 on models with overdrive I hope your 2.7 has a load of grunt or you will be looking for a higher ratio than 4.3 post some pictures of your progress
Post by Phil Nottingham on Jan 17, 2009 16:12:27 GMT
P4 60/75's with overdrives and the 105Rhas 4.7 ratio. I understand Series LR's may fit but I do not know for sure these have 4.7 too
Post by seacutter on Jan 17, 2009 16:52:45 GMT
First drive today!! took her to my local garage and left it for MOT on Monday, the engine as plenty power, 60 on the clock and when you put your foot down it sends you back into the seat.But it seemed to be reeving to high, but the overdrive wasn't working with this fixed it should make it much better. The car is a 1965 Mk2a auto reg. no. CLJ 362 C came from the Bournemouth area a few month ago with a duff engine anyone know any history about this car.The body is good have done no work on it yet only give it a good polish, the underneath only needed 4 small plates welding to the innersills. Went through the brake's and steering all were good. When I get the MOT will tax her and use every day and to a ruining restoration ( I hope)
Post by seacutter on Jan 17, 2009 17:01:03 GMT
Sorry my spelling not to good hope to do a running restoration!! and I hope you dont think I've ruined a good car.
Post by dorsetflyer on Jan 17, 2009 17:05:46 GMT
When I get the MOT will tax her and use every day and to a ruining restoration ( I hope) I hope that's a mis-type in front of restoration. At the moment I cannot recognise the registration so when you get the car returned posting a pic on here would be useful.
Post by johnwp5bcoupe on Jan 17, 2009 19:20:16 GMT
Various ratio's used through the evolution 3.9 Mk1 1A II,3.54 Mk3 auto P5 P5b,4.3 on models with overdrive I hope your 2.7 has a load of grunt or you will be looking for a higher ratio than 4.3 post some pictures of your progress Sounds like a 3.9 which you already have 3.54 will help a bit at least you have some grunt I don't like transplants myself but it's your car
Post by seacutter on Jan 27, 2009 17:08:17 GMT
Hi My diesel P5 is now taxed & tested and in daily use, done over 300 miles, this includes a 140 mile round trip to the coast on Sunday, with no mishaps!! Will post some photo's later if anyone is interested, I made another mistake!! she is a Mk2c not a Mk2a. So starts the RUNNING restoration.
Post by Phil Nottingham on Jan 27, 2009 19:34:36 GMT
How does it handle? Is it quiet to to drive - I know of a couple of P5B's that had conversions years ago and once the axle ratio was sorted drivability was restored but quiteness certainly was not.
These being V8's used the BW35 box which was far from satisfactory but the DG box may be better suited especially with its direct drive top - will it pull away in 2nd as a 3 litre auto should?
Post by seacutter on Jan 28, 2009 17:55:39 GMT
Hi, The ride, handling, steering & braking seem fine. When I get the wheels & Tyres sorted I will fit new shockers of the P5B as the diesel engine is around the same weight as the V8, it also may need lowering a touch. It is that quiet that you can here the click tick!!! well not really, but you can hold a conversation at 65 mph with out SHOUTING and there are no carpets in as yet. The gearbox is not the BW one, it is the one fitted to the Nissan engine 3 speed with a proper o/d with a final drive of 0.686, this works very well. Will try to post some pic,s, do I need to start a different topic?
Post by Phil Nottingham on Jan 28, 2009 19:35:36 GMT
A new topic hleps on SEARCH but not compulsory
