Post by dmaxwell on Feb 17, 2009 15:56:44 GMT
As my 3L P5 has sat for 12 years or so, I know I need(or should to make sure I can stop) rebuild all the brake componets. I've found kits for the master cylinder and wheel cylinders but nothing for the cylinder that is on the power booster. Will the parts for the master cylinder fit the power booster cylinder (I've not started the rebuilding process nor have I purchased the kits yet, just trying to plan ahead)?
Thanks!
David Maxwell Tehachapi, California
Post by Phil Nottingham on Feb 17, 2009 17:13:03 GMT
A separate kit is necessary to recondition the power booster or Servo as we call it.
Trouble is the Girling Mk2 Servo is now obselete and does not reliably recondition and was never as good or relaible as the later Lockheed Type 7 which is a better upgrade and chepaer too
