Post by Eric R on May 9, 2009 8:43:00 GMT
Aimed at Philnotts! DG has a power steering unit from a Mk11. Will it fit to my 1959 Mk1 which long ago had the alternator changed to a Bosch alternator?
Post by Phil Nottingham on May 9, 2009 8:47:29 GMT
Yes but you may have to fit the subframe mounts - the boxes never changed apart from seal improvements.
You will have a problem with pump though which is mounted on the end of the specially dynamo armature and end plate. So you will have to either convert back or work out some other way to fit a belt driven pump unless you can find an electric one.
There is no room to mount the pump on the LHS of the engine as with V8's
