Post by norvin on Jul 30, 2009 15:48:35 GMT
My ammeter flicks instead of holding a steady charge, I have looked for loose connections, it had a new alternator, a 6RA relay and a 4TR regulator about four years ago, any advice would be welcome.
Post by Phil Nottingham on Jul 30, 2009 16:45:36 GMT
Sticking/worn or dirty field brushes - internal break in cables, corroded terminals (the main junction is under the just where a leaky windscreen drips!) faulty 6RA test it by bypassing)
Have you got an electric pump?
Post by johnwp5bcoupe on Jul 30, 2009 17:19:06 GMT
My ammeter flicks instead of holding a steady charge, I have looked for loose connections, it had a new alternator, a 6RA relay and a 4TR regulator about four years ago, any advice would be welcome. Just in case check the shunt accross the meter
Post by norvin on Jul 31, 2009 6:25:48 GMT
Thanks, will check it out, have electric pump but was flicking before I had the e/pump.
