Horns
Aug 1, 2009 22:56:57 GMT
Post by galbrac on Aug 1, 2009 22:56:57 GMT
Hi, sorry if this a duplicate, first note appears to have gone into hyperspace, my fault.
I have a 1970 coupe and the horns have given up , they sound like a hoarse toad. Can anyone recommend good replacements that sound the same as the originals.
Thank you in advance, Cairns Galbraith.
Horns
Aug 2, 2009 5:43:25 GMT
Post by johnwp5bcoupe on Aug 2, 2009 5:43:25 GMT
Hi, sorry if this a duplicate, first note appears to have gone into hyperspace, my fault. I have a 1970 coupe and the horns have given up , they sound like a hoarse toad. Can anyone recommend good replacements that sound the same as the originals. Thank you in advance, Cairns Galbraith. If you can't find any good original P5 ones there are loads out there which sound similar/same like the Range Rover there are usually loads on Ebay
Horns
Aug 2, 2009 11:14:57 GMT
Post by Phil Nottingham on Aug 2, 2009 11:14:57 GMT
Look for windtone type - they are plastic but sound the same - Vehicle Wiring Products
Horns
Aug 2, 2009 20:48:21 GMT
Post by galbrac on Aug 2, 2009 20:48:21 GMT
Thanks, did not realise Range Rover had similar horns. I have a bid on ebay for a pair. Thanks again.
Horns
Aug 2, 2009 22:15:33 GMT
Post by Colin McA on Aug 2, 2009 22:15:33 GMT
Cairns I was going to give you a ring, You should be able to repair your horns.
I will see you at the meeting on Wednesday.
Colin
