Guus
Post by Guus on Aug 30, 2009 12:26:26 GMT
Won't leave you at peace... I replaced the flash-unit with a new one from Wadhams, and all seemed fine. On the first drive however, on clipping the flash-rod, a slight shock is felt through the car, the rev-counter stops and the flasher stops flashing. Any ideas? Thanks again...
Post by johnwp5bcoupe on Aug 30, 2009 13:44:42 GMT
Won't leave you at peace... I replaced the flash-unit with a new one from Wadhams, and all seemed fine. On the first drive however, on clipping the flash-rod, a slight shock is felt through the car, the rev-counter stops and the flasher stops flashing. Any ideas? Thanks again... They are both fed from the ignition switch position 2 the indicators are fused 3 and 4 fuse but the rev counter is straight from the switch along with the starter motor 6RA and the ignition so I cant see the "connection" between the two faults as you were still running and can start the engine
