Post by eisdielenbiker on Aug 31, 2009 7:31:55 GMT
Hello, I just had to put the Rover aside for the radiator repair. This lasted nearly 3 weeks including some additional restoration in the engine bay. Usually my P5B is not stationary for such a long time. And she instantly replied it with a temporarily non working RH indicator light. After driving a few miles it came on in the evening again. Strange is'nt it ? When inoperative all flashing lights were working though. It was just the RH indicator light missing... Never occured again during the last few days. Mark
Post by Phil Nottingham on Aug 31, 2009 7:40:54 GMT
Either wrong flasher unit is fitted or it is still drawing sufficient current to operate almaost normally 60-120 fpm.
clean connections/bulbholder/bullets/earths
Post by RedP5B on Sept 1, 2009 16:20:53 GMT
My indicators always work but very irregularly/slow.
Post by Phil Nottingham on Sept 1, 2009 20:32:02 GMT
Same problem - the actual fitings corrode giving high resistance so low current and slow flash. remove bulbs and earths and check ALL bullets and clean.
If still a problem replace unit - Vehicle Wiring products do one - it is round not oblong but will work
