Post by Deleted on Sept 5, 2009 15:35:30 GMT
My P5b amp-meter has started to 'flicker' at about one blip a second, after about ten miles , the ignition light joins in, bit worried about a long distance journey, I've checked all connections. Any ideas anyone
Post by johnwp5bcoupe on Sept 5, 2009 16:17:45 GMT
Difficult to say that's it but I would check the Alternator the 3AW Relay and the Control 4TR basically it's a process of elimination as the car is running ok and you have done the basic checks
Post by norvin on Sept 5, 2009 17:02:54 GMT
Mine was the same but when some of the wiring shorted out and melted I had to make up some new earth wires as they had melted around the 4TR and the relay, which cured the flick so it might pay you to check the earth wiring.
