Post by patrick on Nov 23, 2009 18:37:00 GMT
Bonsoir, I have to open the high engine, being this one blocquƩ. Have to I rectify the breech for the reassembly and if yes what is the quotation of rectification? In advance, Thank you. Cordialement, Patrick
Post by Phil Nottingham on Nov 23, 2009 18:40:57 GMT
For breech do you mean cylinder head? This is alloy and can distort and then has to be skimmed dead flat and very smooth after removeal of teh inlet valves
Post by patrick on Nov 23, 2009 19:38:35 GMT
Bonsoir,
OK, thank you. It is for my 3 liters. The quotation has to be of 0,5mm or more? Or less? Find t one this value in the textbook(manual worker)? Cordialement, Patrick
Post by Phil Nottingham on Nov 23, 2009 22:58:02 GMT
Still not entirely clear it is the cylinder head you mean - I assume the head gasket is blowing. Or do you mean the inlet or exhaust manifild gaskets?
0,5mm is absolute max for a head skim as the inlet valve pushrods will then be too long and also the water pump "O" ring too compressed. The sammlest amount must be removed
