Post by patrick on May 1, 2010 11:40:18 GMT
Hello to All. I resumed(took back) the works on my Belle P5 cut 3 liters. The engine being blocqué, I try in vain of him(it) freed before a complete dismantling. I have déculassé, 6 cylinders are very appropriate(clean), but the stuck pistons. I tried of the WD40 and the height of the engine in fuel oil (30 liters), but I arive not no to unstick the engine nevertheless. If you had this problem and find an idea to unstick him(it), I am for your listening. By avnce, Thank you. Cordialement, Patrick
Post by enigmas on May 1, 2010 12:37:28 GMT
I should have paid more attention to my French lessons at school!
I believe it's seized? Patrick, fill the cyls with ATF (Automatic Transmission Fluid) and leave it alone for several weeks. Then try and turn it over with a big spanner on the harmonic balancer bolt (bottom engine pulley) on the front of the engine. Be very gentle
rcoups
Post by rcoups on May 2, 2010 7:23:05 GMT
Last time I had one of these engines that was seized the only way of freeing it was to strip it top and bottom and tap the pistons out with a block of wood and a mallet
Post by johnwp5bcoupe on May 2, 2010 9:12:16 GMT
Last time I had one of these engines that was seized the only way of freeing it was to strip it top and bottom and tap the pistons out with a block of wood and a mallet Patrick if it's that seized it would be silly not to remove the pistons just to check the rings (replace) and clean up the bore! replace shells etc
Post by patrick on May 3, 2010 19:32:53 GMT
Bonsoir,
OK, I think of it more and more. But I wanted to verify before d to put down(deposit) everything. Kind regards,
