rover3l123
Post by rover3l123 on May 14, 2010 23:04:02 GMT
My P5 MK11c has the double ended electric fuel pump. When I switch it from the main to the reserve the pump makes a continuous clicking noise. Is this likely to be a problem with the points?
Post by Phil Nottingham on May 15, 2010 10:22:43 GMT
With engine off it should every 15-20secs at most with it idling perhaps 5-10. Float needle either leaking in carb or fuel line leaks or intake leaks on unions allowing air in.
Does both main & reesrve behave the same?
rover3l123
Post by rover3l123 on May 15, 2010 12:09:35 GMT
No the main is quiet apart from the occasional tick as you describe. The reserve however, makes the constant high frequency ticking
Post by Phil Nottingham on May 15, 2010 13:55:22 GMT
Diaphragm still/badly adjusted air leak in intake pipe or union or dirty burnt contact points
