rcoups
Post by rcoups on Jul 25, 2010 17:37:15 GMT
Hi does any one know where we can get the bearings for the accelerator linkage, have tried emailing wadhams but got no answer from them, or is there away of manufacturing them yourself out of something. Does it affect the kick down on the auto box if you havent got them
Post by Phil Nottingham on Jul 25, 2010 17:53:43 GMT
Search
rcoups
Post by rcoups on Jul 25, 2010 20:26:14 GMT
search? keeps coming up with my post
Post by Colin McA on Jul 25, 2010 21:04:46 GMT
Are you looking for the brass one in the manifold or the one on the kick down bracket?
Colin
rcoups
Post by rcoups on Jul 25, 2010 21:42:16 GMT
the ones that go in the linkage to hold the accelorater arm, it goes across the bulkhead and i think they are rubber
Post by nzchevy on Jul 26, 2010 9:51:20 GMT
I posted a similar request last September. In the end I had a friend of mine turn up some bearings from nylon bar. My car is a 3 litre manual with overdrive so I'm not quite sure if the bearings are identical. I may be able to get some made for you if you can't get them anywhere else.
Regards
Roger
rcoups
Post by rcoups on Jul 26, 2010 10:46:20 GMT
Thanks if I cant I will be intouch, or if you have picture of them I could most probably do some myself
Post by Phil Nottingham on Jul 26, 2010 14:23:26 GMT
They are NLA now - and were also used on a LR - they are the same on manual and ustos and are nylon.
I got 2 from a LR specialist but as in posted Search a few months ago they have all gone now - I had hoped someone on here could turn some up from stock nylon bar as they are nothing special and would I supply a pattern if this would help. Brass would be even better and simpler but some form of locating pin/screw would be required
Post by johnwp5bcoupe on Jul 26, 2010 14:36:35 GMT
If you have the dimensions Phil and what material you want to use I can help you out
Post by Phil Nottingham on Jul 26, 2010 15:56:57 GMT
Thanks John - we can discuss at the National - its good that things are not all one way although nevr been wth you and one or two others
rcoups
Post by rcoups on Jul 28, 2010 9:15:38 GMT
I will be at the national as well so if we can meet up it would be good
Post by Phil Nottingham on Jul 28, 2010 18:15:12 GMT
Ok will be pleased to
