Post by Deleted on Aug 30, 2010 8:57:22 GMT
Hi. can anyone tell me if the vibration damper on 3 litre mk11 suffix a and b is the same as suffix c . I have a 1964 mk 11 (c) and am getting engine vibration. I am going through the motions of sorting out this problem any advice would be welcome
Post by Phil Nottingham on Aug 30, 2010 17:42:46 GMT
No they are all different - why do you think this is the problem and say a UJ or worn engine mounts
Post by Deleted on Sept 4, 2010 4:20:20 GMT
thanks for the advice . I know that the damper is not suffix c so i will replace it. also i am in the process of renewing the prop uj's all engine mounts are new.any idea where i can get a c damper .
Post by Phil Nottingham on Sept 4, 2010 8:17:30 GMT
Try David Green
Post by Deleted on Sept 7, 2010 7:41:41 GMT
thanks . I will call him today
Post by johnwp5bcoupe on Sept 8, 2010 7:53:49 GMT
So for clarity you have either a suffix "A", "B" or Mk3 fitted?
Post by Deleted on Sept 9, 2010 21:38:47 GMT
The damper fitted was off a suffix b .so if I can find a suffix c ,hopefully this willsolve the problem.thanks
