rover3l123
Post by rover3l123 on Oct 10, 2010 22:21:25 GMT
Does anyone know what the points dwell angle should be for the Rover P5 mK11c
I have searched the forum but did not get any hits.
Post by dmaxwell on Oct 10, 2010 23:38:27 GMT
My workshop manual doesn't list a Dwell angle but it does say the points gap should be .014" to .016".
David
Post by Phil Nottingham on Oct 11, 2010 19:01:00 GMT
Dwell for a 25D6 dizzy is 35º +/- 3º ie Mk2's onwards. Mk1's with earlier DMBZ6 dizzy is 38º.
These are standard Lucas settings
rover3l123
Post by rover3l123 on Oct 17, 2010 16:51:42 GMT
Thanks, I set it yesterday, it was quite a way off. It runs much smoother now and I also took the opportunity to fine tune the mixture. I am at the point where I can balance a threepenny bit on the air filter without it falling over when the car is at idle.
I still have some small problem with the throttle linkage as it idles too fast but I can get it back to normal by blipping the throttle quickly.
Weak spring maybe?
Post by Phil Nottingham on Oct 17, 2010 19:01:07 GMT
Good - may be the spring bracket is bent? Too string a spring can be tiresome and make smooth driving dificult. Worth try it though
Post by Deleted on Nov 9, 2010 21:55:33 GMT
I know you ca get proper dwell angle readers but could it be done by the way descibed below.
Remove dizzy cap Plug a spark plug directly in to the coil out put and connect the plug to earth. Rotate the enine until the spark. Mark the crank pully. Rotate the engine again until the next spark. Then mark the crank pulley again. Take the degrees move on the crank pulle and divide by 2. (because the crank rotates twice to every cam/dizzy rotation.)
Ive never heard of it being done this way but by logic, it should work.
Post by Deleted on Nov 9, 2010 22:02:01 GMT
just realised that only gives you the time between sparks and not the time the points are actually closed. Ill have to rethink...
