Post by Deleted on Feb 15, 2011 20:00:20 GMT
Is anyone selling, or, knows someone who is selling a pair of rear headrests in Buckskin for my p5b Coupe?
If all else fails I will of course look to get ones of a different colour and get them treated
Cheers
Post by Deleted on Feb 15, 2011 20:15:53 GMT
Post by Deleted on Feb 15, 2011 20:27:37 GMT
Cheers for the quick reply and the Ebay prompt
Yeah I think you're right that they were only meant for saloons but quite a few owners have stuck them in coupe's
I'll just get my rear passengers to lie across the seats!
Cheers
Post by Phil Nottingham on Feb 15, 2011 22:34:38 GMT
Wadhams once had some made to fit Coupes - trimmed in leather in choice of colour
Post by Colin McA on Feb 16, 2011 10:07:25 GMT
You can fit them but what you will find is that they sit close/touching the screen. It also pushes the seat back and puts tension on the screws which hold it to the frame. If they break free it shows an unsightly gap.
Colin
tonys
Post by tonys on Feb 17, 2011 12:13:47 GMT
As far as I am aware they (rear headrests) were only ever originally listed for saloons. I always assumed that it was primarily because the backrest on the coupes was at a different angle to that on a saloon, thus making the fitting different. They can obviously be made to fit, as others appear to have done it, but, as Colin has said, I would also think that they would be very close to the actual screen and would probably significantly reduce rear visibility due to the angle of the screen.
Post by Deleted on Feb 17, 2011 21:35:11 GMT
cheers for these replies fella's, it all helps. I suppose I was contemplating purely for asthetics and not soley for head support!
Colin, you make a strong point to consider re the possible breakage of the holding screws.
By the way, do any of you know the best way to educate a paperboy to leave his bike at the end of your drive and not cycle within an inch of the P5 and more to the point, an inch of his life!!
Cheers Andrew
Post by Phil Nottingham on Feb 17, 2011 22:29:59 GMT
Post by Warwick on Feb 18, 2011 0:23:57 GMT
By the way, do any of you know the best way to educate a paperboy to leave his bike at the end of your drive and not cycle within an inch of the P5 and more to the point, an inch of his life!! Cheers Andrew I've seen things that can be used for that purpose. Research has shown that they accelerate the learning process so that only one lesson is required. You can probably get them in the UK. I think they are called Rottweilers.
Post by Deleted on Feb 20, 2011 14:11:46 GMT
I'll get on ebay and buy a rottweiler..... and maybe they'll throw in some headrests!
Post by Roverboy on Jun 14, 2013 5:50:35 GMT
Hi for what its worth I bought some rear headrests for our p5b coupe from J R Wadhams for 100 pounds They do all the colours .They fit very easily they just sit over the back seat. The only problem is they can move around abit if going around tightish corners Im thinking a velcro dot to keep in place Hope this helps.
Post by davewright on Jun 14, 2013 10:20:27 GMT
I just fitted Wadhams headrests and used self adhesive strips of velcro to hold them in place. I also had to modify one to fit around the rear seat belts.
Post by Dean Hovland on Jun 16, 2013 18:53:03 GMT
If you fit rear head rest you cant get baby seats in the back .
