Post by Gordon Harrower on Jul 29, 2011 1:20:19 GMT
Today I set about what I thought would be a straightforward job in getting the headlights and sidelights working on my P5 (1963 Mk IIa 3-Litre Saloon, LHD, positive ground). Unfortunately, it appears that someone at some time rewired the lighting circuit, at least behind the dash binnacle, and with non-standard wire colors. I'm trying to make sense of the wiring diagram to see how things should be, but between the unorthodox changes and the nest of wires back there, I'm having a hard time. There don't seem to be enough wires connected to the main headlight switch, either.
Would someone be willing to take and send pictures of the headlight switch (top right) and dimmer switch (top left) wiring?
Thanks,
Gordon.
Post by Phil Nottingham on Jul 29, 2011 21:30:35 GMT
Not sure that a picture would be much help - the wiring is basically simple - the only slight complication is the parking light circuit and panel special switch - you are aware that the console switch is the main switch with the column switch for side or heads and the floor switch for main (high) beam/ dip (low) beam?
I can send you a Pdf in colour of the P5B diagram which is the same as regards the switching
Post by Gordon Harrower on Jul 30, 2011 0:10:33 GMT
Phil,
Thanks, as always. Any information would help. Everything I do on this car is a learning process.
My email address is: gharrower200@gmail.com
Gordon.
Post by barryr on Apr 27, 2012 15:18:27 GMT
Hey Phil, My bike forum has a useful downloads section with pdf's etc in - shouldnt we have something similar on here? if not can I get a colour copy of the wiring diagram? Many thanks Barry
Post by Phil Nottingham on Apr 27, 2012 17:49:08 GMT
Good idea - but I only moderate posts and do my own not maintain the forum so perhaps DD can comment.
Wiring diagrams are for P5OC members only - this was the condition of the person who took a lot of time drawing them from the awful Rover/BLMC versions. The numerous errors have also been corrected which BL never bothered to as no money left
At present members email me and I send it back by return - either the colour version or the large print line drawing one for colour challenged indivuals
Post by johnwp5bcoupe on Apr 27, 2012 19:04:35 GMT
OOps sorry Phil I thought they were in the Members only section then I found my post
Post by barryr on Apr 27, 2012 22:46:44 GMT
Sorry - I was meaning to suggest a download section to all to see what group opinion was.
I've been a member of the club for years Phil so I'll send u a pm re diagram.
Cheers
Barry
Post by David on May 2, 2012 12:46:38 GMT
Just read this, so sorry for the late reply.
I would suggest using 'The Rover Vault of Knowledge' in the 'Members Only' area. Fortunately, it is very easy for members to upload their PDFs etc. so I cannot see it being a problem.
Post by Phil Nottingham on May 2, 2012 16:48:07 GMT
I did not know I could upload them there - must try it!
