Post by spanner on Sept 3, 2011 20:07:32 GMT
Hi Guys,
Managed to get a supply of bulbs to match the manual's data sheet, so i proceeded to change them. The main dash lights were easy enough, but the long thin instrument lights???
I was able to remove the bulb holders for the rear of the instrument lights. However, They are so deep, I could not figure how to get the bulbs out.
Can you tell me how please?
Cheers
Spanner
Post by johnwp5bcoupe on Sept 4, 2011 5:42:15 GMT
The bulb holder separates from the tube
Post by spanner on Sept 4, 2011 14:15:29 GMT
Thanks John, is this a twist off or pull action. (are they treaded?)
Thanks/ BTW, do you have a bulb ref for these ones, number and performance please?
Cheers
Spanner
Post by Baldrick on Sept 4, 2011 15:19:42 GMT
Spanner, if my iPod forum app works, a picture show show the holder from the rev counter below.... Attachments:
Post by Baldrick on Sept 4, 2011 15:21:57 GMT
Great, that worked a treat... Here is rev counter with bulb holder removed. It should come out with a wiggle as opposed to twisting or pulling I hope this is what you were looking for Attachments:
Post by spanner on Sept 4, 2011 19:40:54 GMT
Thanks so much for that. I had done those two pieces. My query is the small lights behind the switches for the instruments, wiper, heater etc. They do easily detach from the rear of the dash, however, they are very long tubes compared to others. The bulb rests at the base and you cannot get your fingers in.
I hope I am being clear. Should of course taken photo's but I will the minute I get a chance.
Thanks so much again.
Cheers
Spanner
Post by johnwp5bcoupe on Sept 4, 2011 20:17:43 GMT
The bulb holder just pushes in the tube! twist and pull.
Post by spanner on Sept 5, 2011 8:31:15 GMT
Will give this a go. Thanks a mil.
Spanner
trymes
Post by trymes on Sept 6, 2011 0:08:38 GMT
If that doesn't work, a short length of clear plastic/vinyl tubing is often handy.
Post by spanner on Sept 12, 2011 14:29:00 GMT
This worked a treat, thanks. Have changed with standard bulbs for now. Have LEDs on order. Hope that works out.
Cheers
Spanner
trymes
Post by trymes on Sept 13, 2011 16:15:36 GMT
How did you end up doing it? Just removing the holder, or the tubing?
Tom
Post by Baldrick on Sept 13, 2011 17:16:47 GMT
Spanner,
Where did you order the LEDs from?
Post by Phil Nottingham on Sept 13, 2011 19:03:43 GMT
Any pics/tips
Post by spanner on Sept 21, 2011 8:54:21 GMT
How did you end up doing it? Just removing the holder, or the tubing? Tom This time I was more confident and was able to just remove the bulb holder. Nice one.
Post by spanner on Sept 21, 2011 9:00:07 GMT
Spanner, Where did you order the LEDs from? I ordered the from a local motor factors. Lots of trial an error going on at present as LEDs do not always give the same effect. eg, if the external side lights are changed to (one direction/projection) LEDs the PIPs do not light up the same way as with the old bulbs. this type of thing. I am not out of the woods yet. But when I have them sorted I will post bulb refs and manufacturers. I am sure they will be cheaper in the UK.
Post by spanner on Sept 21, 2011 9:02:54 GMT
One really useful tip that saves scraping your knuckles was to remove the trip counter reset knob under the dash.this meant that the dash slipped out nicely and you could see what you were doing. It certainly cut the time taken too. I will post pics when I get a chance. Busy at work for a pleasant change so I am grabbing it with both hands.
