Post by Deleted on Jan 4, 2012 16:40:53 GMT
Bidding on a period radio at the mo on" The Bay", then realised I didn't know where the speaker(s) would be if they were factory fitted. Would it have been a single speaker behind a grille as found in the P4? Not to keen on fitting any on the scuttle, did that on another classic I owned and I kept catching them with my feet whilst getting in and out ! So, where would they have been fitted ? A search on the site came up blank.
Post by p5coupepaul on Jan 4, 2012 18:10:15 GMT
on my p5 its just above the radio behind a grille but i have seen some early p5 s with a single one on the rear shelf hope this helps paul
Post by barryr on Jan 4, 2012 19:10:21 GMT
My 72 Saloon has one in the grille above the radio and one in the middle of the rear shelf as original. Also has a fader control between the seats for front rear fade. I was talking to some guys at the NEC (from Autosound) about their retro looking radios with fm and ipod dock etc. They sell some replacement speakers that will normally fit original apertures and some have multiple drivers as well. I was going to look into this for getting a good balance between sound and period looks. link is: www.autosound.co.uk/acc/classic.phpmy car still has an 80's 2 spindle radio cassette fitted which works well except for the awful standard speakers!
Post by johnwp5bcoupe on Jan 4, 2012 20:06:07 GMT
I used two small Bose speakers that just fit under the parcel shelf, covered them in the same Vinyl as the door trims etc covered the fronts in matching speaker cloth no alterations or screwing hard to see which was my intent! they sound fine to me they probably lack a bit of base to the ICE connoisseur
Post by Phil Nottingham on Jan 4, 2012 20:06:25 GMT
Special radio fixing kit similar to P4's but not the same with grille above. Same on P5 and P5B'S and replaces centre glove box and lid.
Optional rear shelf speaker - P5B had holes punched in shelf but grill had to be fitted in P5's. Volume/balance control fitted to heater switch on tunnel in P5B's
Post by Deleted on Jan 5, 2012 10:50:03 GMT
Thanks everyone...as helpful as ever. I have a few ideas to work with now,great !!
Post by barryr on Jan 16, 2012 12:54:26 GMT
Doh - realised I posted the link to the American supplier of that stuff. The guys I spoke to at NEC were: www.classiccarstereo.co.ukCheers Barry
Post by Deleted on Jan 16, 2012 17:46:32 GMT
That's ok Barry, I figured something was not quite right....Thanks again for the link.
Post by Colin McA on Jan 16, 2012 20:10:43 GMT
I replaced the single front with two smaller high output sony speakers.
was going to fit similar in the rear but couldnt get small enough ones to fit the space.
Colin
Post by barryr on Jan 16, 2012 23:18:03 GMT
The guys I spoke to had a single speaker with dual voice coils so you feed them a stereo pair. Thought it would be interesting to replace my single front and single rear with those. Less than 50quid a pair too.
Loads of other jobs for me before that though!
Post by Phil Nottingham on Jan 17, 2012 18:55:10 GMT
Is it really Hi-Fi though!
Post by barryr on Jan 19, 2012 12:53:09 GMT
Nah but I have subs and all that in my daily driver
so not really needed for the old bus! - just a better sound from standard locations and not a door card cut in site.
That company do conceled speakers that can be mounted under the seat etc as well.
Post by cyf on Sept 22, 2012 16:43:15 GMT
I used two small Bose speakers that just fit under the parcel shelf, covered them in the same Vinyl as the door trims etc covered the fronts in matching speaker cloth no alterations or screwing hard to see which was my intent! they sound fine to me they probably lack a bit of base to the ICE connoisseur Hi, Do you have pictures of the set up, John? My wife and kids are missing the music in the car, so I'll have to do something. Were is your radio fitted?
Post by cyf on Sept 27, 2012 10:16:23 GMT
What I want is keeping the center glovebox useable and make no holes in the door panels for the speakers. So the radio and speakers must be hide in the parcel shelf under the dashboard
Did some of you make this type of installation? Pictures welcome
Post by petervdvelde on Sept 27, 2012 21:11:26 GMT
Cyf,
In my MG i made some small speakers under the dasboard. The speakers were in its own plastic housing (approx 12x12x10cm) and i made some brackets to fit them. Peter
Post by cyf on Sept 29, 2012 22:37:37 GMT
Thank you Peter, but I would like to see the set up in a P5 if it's possible
Post by johnwp5bcoupe on Sept 30, 2012 7:45:47 GMT
I used two small Bose speakers that just fit under the parcel shelf, covered them in the same Vinyl as the door trims etc covered the fronts in matching speaker cloth no alterations or screwing hard to see which was my intent! they sound fine to me they probably lack a bit of base to the ICE connoisseur Hi, Do you have pictures of the set up, John? My wife and kids are missing the music in the car, so I'll have to do something. Were is your radio fitted? Hi Cyf my speakers are just the right size to be a tight fit under the dash I never measured them I covered them in the same material as the dash and the cloth on the front is a matching shade, they are not fixed as I said they are good fit, my radio is in the center glove box with a matching veneer IF I remember I will send you a picture a bit busy at the moment so "I will try to remember"
Post by Ken Nelson on Jul 2, 2017 15:10:29 GMT
Does anyone know of a source to buy a proper replacement sized speaker for the factory front grill mounting in a P5 Coupe? The original speaker measures 4"x7" with mounting holes 3 5/16" apart in both length and width.
