Post by Phil Nottingham on Aug 13, 2007 17:05:04 GMT
As no-one has publised this on here as yet is anyone going its less than 3 weeks way now. Its in the NW at Haigh Hall nr Wigan - will there be any Rover autojumblers there?. How many are going , we are if that is any help
Post by Smallfry on Aug 13, 2007 22:08:02 GMT
Too far for me unfortunately.
Post by Deleted on Aug 14, 2007 7:53:33 GMT
Post by Phil Nottingham on Aug 14, 2007 18:38:00 GMT
It is a lot of bother for just one bush - its best to do all of them on that side as it involves stripping the whole suspension down.
Bad cheapo design as if the rear bracket had been bolt on rather than welded it would be a 10 min job!
Someone on the old board has done this - but you need access to thick metal and a good welder
Post by Deleted on Aug 15, 2007 9:07:14 GMT
Thanks Phil, I tried to do this job at home on the drive but chickened out. I am hoping we can do it on a ramp at work this week! Adrian
Post by p5tgc on Aug 15, 2007 17:09:41 GMT
At least 3 cars traveling down from Scotland to the National Rally & Dinner.
Post by Phil Nottingham on Aug 15, 2007 17:45:32 GMT
The weather forecast looks terrible for the whole weekend - however we are going to try to get there so I hope those up North can make their way down.
The museum is excellent anyway so even if its is raining there is no need to get wet
Post by Welsh Warlock on Aug 15, 2007 21:45:12 GMT
At least 3 cars traveling down from Scotland to the National Rally & Dinner. Trevor, surely at least 4? You, Jim, Cairns and Tom?
Post by Phil Nottingham on Aug 15, 2007 21:49:29 GMT
Freddy - this is one of those jobs that looks dead easy until you try it!
I will be interested how your garage goes about it as the w/s manual gives no help in this matter! I have done 3 so far and removal of the bottom link after releasing the torsion bar tension seems to be the only way to me.
I have heard of someone cutting the rod halfway along and presumably welding it or threading it so it can be screwed/twisted back together. This also sound dubious as it may pull apart
This seems too drastic! The tube is actually hollow and can get bent or dented if too heavy handed. Perhaps being Aston Martin experts they can design a solid version in 2 parts, could be useful sideline?
The cup washers at the rear mounting also rust away, if they are damgeed they will cut into the new bush, which is round on later versions. It becomes much flatter when the rear castle nut fastened up
Post by p5tgc on Aug 16, 2007 13:16:39 GMT
Alan, The numbers keep growing, "Molly" will be there too!
Post by Deleted on Aug 16, 2007 15:59:14 GMT
Phil, the evil deed is done! We only did one side today and we seperated the top ball joint quite easily, wound out some tension at the rear ride height adjuster and after disconnecting ARB, damper etc, removing cailper (and tying it out of the way) we lowered the arm and then unbolted it and pulled off the arm from the torsion bar - phew!! Then removed the radius arm from the lower arm (inner sleeve of rubber bush rusted on to arm - heated it and got it off. Fit new metalastic bush to rod and arm, new gaiters to upper and lower ball joints (lower kingpin gaiter from Aston Martin DB6 !) Refit assembly. arm to torsion bar and fiddle with ball shaped bushes in to chassis (what a fiddle). Not a job to repeat in a hurry !
Thanks for all advice and tips from everyone on this forum.
Cheers
Adrian
Post by Phil Nottingham on Aug 16, 2007 16:07:51 GMT
That is the only way I have found to do it - not a 5 min driveway job!
One it did the torsion bar leaves separated so I had to make a clamp to pull them together so the bottom link would go back on. Sometimmes they rust solidly into the link and the back adjuster.
Never had any problems with separating the ball joints though many do
Post by Phil Nottingham on Aug 30, 2007 16:57:18 GMT
To get back on the subject
How many are going this weekend, its a good long run for us (200 odd miles round trip again but unlike Duxford we are not into stately homes at all so it will just be for the (P5)cars.
I also have to be back at work early Monday so do not want to make it a waste of effort.
The weather does not look too brilliant so far but better than it was at Duxford, so is it worth it?
What do the locals say up north?
Post by Welsh Warlock on Aug 30, 2007 17:18:07 GMT
I shall be going with some friend but unfortunately sans p5 as the gearbox is out and won't be back in until at least next week!
Second major Rover event this year that I have been without a P5! This could become a habit!
Post by Phil Nottingham on Aug 30, 2007 18:56:23 GMT
It can be like that - that's I have 2
Post by johnwp5bcoupe on Aug 30, 2007 20:50:39 GMT
I would love to attend Phil but 400 miles round trip is a long way on a car that has only done 170 since a total rebuild I know you would say it's a good test but the weather looks a bit dodgy and if I was unlucky in breaking down I would rather it was in the dry next year
Post by Deleted on Aug 31, 2007 8:19:50 GMT
Now thats what I call a long range weather forecast!!!
Post by Warwick (Ozcoupe) on Aug 31, 2007 8:55:36 GMT
I would love to attend Phil but 400 miles round trip is a long way on a car that has only done 170 since a total rebuild I know you would say it's a good test but the weather looks a bit dodgy and if I was unlucky in breaking down I would rather it was in the dry next year And this from a man who for fun drove karts for 24 hours with a lap full of snow! You need a good brolly John.
Post by johnwp5bcoupe on Aug 31, 2007 10:12:59 GMT
