Post by dorsetflyer on Dec 21, 2004 11:01:42 GMT
Author: Chris Discombe- Torquay Date: 12/21/2004 4:14 am EDT Hello and merry xmas to all. My question at this time is about the lock barrels in the front doors of a p5b. The drivers door is becoming increasingly difficult to open due to the lock barrel being very worn. Has anybody successfully repaired one before and could give me guidance as to how to . Or does anyone know where i can purchase good second hand ones or even better new ones. Regards Chris Discombe
Post by dorsetflyer on Dec 21, 2004 11:03:30 GMT
Author: Adrian - Swadlincote Date: 12/21/2004 6:27 am EDT Try David Green, he has lots of used spares. Contact him on : david@greenp5.fsnet.co.uk
Post by DanielSheard on Dec 21, 2004 11:40:46 GMT
JRW does (or did anyway) high security inserts. The standard lock barrels can be turned with a screwdriver iwhen they are worn!
Daniel
Post by Phil Nottingham on Dec 21, 2004 19:45:23 GMT
You do not mention whether its a saloon or coupe as the locks are totally different.
I covered this for the saloon on the old Board - if you have a saloon I will search and locate it. Both types are repairable though with a matter of ingenuity and nw/secondhand parts
Post by dorsetflyer on Dec 21, 2004 20:27:33 GMT
Phil, Chris's car is a saloon, looks like the twin of mine
Post by dorsetflyer on Dec 21, 2004 20:34:37 GMT
That sounds like my old Tranny, any old key you had in your pocket would open the doors and turn the ignition on let alone a scewdriver.
Post by Deleted on Dec 21, 2004 23:37:24 GMT
all old cars are like that .try putting a little lube in them and leave to soak this is alot cheaper if it works
Post by Chris Discombe on Dec 24, 2004 18:30:03 GMT
:)Have been led towards this new site so here goes. David green has made contact and is attempting to get me some better s/hand ones Regards Chris Discombe
