ged
Rover Newbie
Post by ged on May 21, 2013 15:07:59 GMT
what will special tool 601467 do exactly ? can one be acquired from anywhere ? or can gearbox be removed without one?
Post by harvey on May 21, 2013 15:57:45 GMT
I had to look that one up.
All it's supposed to do is stop the converter moving forward when removing/refitting the gearbox/bellhousing/converter as one unit. It's not required if you remove the box from the bellhousing, and then remove the bellhousing and converter separately afterwards, which is the easiest way to do it anyway.
ged
Rover Newbie
Post by ged on May 22, 2013 7:27:37 GMT
thanks for info. will do it your way.
