Post by duncan1 on Aug 11, 2013 7:37:06 GMT
Hello. Has anyone had trouble fitting new door cards to a coupe ? I most certainly have. The cards(purchased from Wadhams ) are an absolute nightmare to fit. The front ones were extremely hard where as the back ones don't seem to fit at all. The shape appears to be wrong around the rear wheal arch and also seam to be a little too wide. Basically the doors won't shut. The other problem is getting the clips into the door cards and lining them up with the fixing holes in the doors. Any advise would be greatly appreciated.
Post by Kev on Aug 11, 2013 9:10:08 GMT
Hi,
I would have a word with JRW if I were you.
Big Kev.
Post by Multi-Tech on Aug 11, 2013 13:55:00 GMT
I agree with Kevin, your first point should be to call JRW and see if it is a known fault as he could have had a bad batch made?! Do you still have your old door cards to match them up to?
Post by duncan1 on Aug 12, 2013 23:10:20 GMT
Thanks very much for your replies! I had some spare old door cards which I was sble to fit (easily!) ill contact Wadhams though and hopefully they'll be able to resolve the problem for me. Thanks again!
Post by Kev on Aug 19, 2013 16:53:35 GMT
Any news ?
Big Kev.
