Post by Chuck Berry on Dec 10, 2013 8:32:25 GMT
P4 and P5 door shims.... Does anyone know if they are the same please? Will The P4 ones fit on a P5? Many Thanks Chuck
Post by Chuck Berry on Dec 13, 2013 9:55:15 GMT
Anyone?
Post by David on Dec 13, 2013 11:59:01 GMT
I understand they are one and the same, but cannot verify. Probably your best option is to PM Phil as he is the 'Yoda' of all things Rover
Post by enigmas on Dec 14, 2013 2:31:20 GMT
I make these using mountboard picture framing card for both my P5 and ZB Magnette. My Rover was done 20 years ago and the door is still fine.
Post by Chuck Berry on Dec 14, 2013 7:56:35 GMT
I am surprised at that. Would it not compress after a time? Isn’t mountboard picture stuff hydroscopic or do you have a plastic type material? Do you have any water/rust problems in the area round the hinges due to the rain etc., being absorbed?
Sorry to question your very good intentions, but I am taken back at the idea. Perhaps I am missing something (commonsense or ...) obveously if it lasted 20 years it must be good
Post by enigmas on Dec 14, 2013 10:42:30 GMT
No, there are no issues like that. If you think about the placement of the shims between the A or B pillar and the hinge. Once tightened there is some compression and that's it. Moisture does not get between the 2 flat mating surfaces due to the clamping pressure. I still have a container with some spares I made all those years ago. I cut the shape with a stanley knife and use hole punches. They are not visible behind the hinge unless many are required which would mean other body alignment issues need attention. You could easily cut them from thin gauge aluminium but I've never found it necessary. Try it, it'll cost you virtually nothing and it works. You only require a small piece of card.
Post by Deleted on Dec 15, 2013 9:50:47 GMT
I'd go along with that. I packed out the badly dropped door on my old taxi cab with card as a 'temporary' measure years ago.Its still there and the doors fine. Forgot all about it until I read this post.
