Post by fragile on Dec 29, 2013 14:12:23 GMT
Hi Guys From the day I got my p5b 1972 rover saloon the interior lights have not worked. Had a couple of days to play over xmas , Clock works, Cig lighter works so fuse is ok under dash, I have looked at all connectors that had purple wires in, all giving 12volt. Interior lights removed, all 4, no power on purple wires, also lights in headrest has no power. looked in workshop manual this pointed to the first light in line would be passenger front, from what I have found so far the cables run to rear passenger light first and come up from boot area. I cant find a connector in that area, any help where the connectors are hidden, to prove things are working, I linked a wire from clock purple wire to front passenger purple wire, all door lights worked when correct doors open, headrest lights still did not work. Anyone had problem like this before and know where the connectors are Thanks Neil
Post by johnwp5bcoupe on Dec 29, 2013 14:51:50 GMT
Neil from memory the door/interior light loom is fed from the main loom at the rear passenger side so check there? if no supply check the main loom connections passenger side under the kick panel normal problem probably corrosion in a bullet connector? good luck
Post by Phil Nottingham on Dec 29, 2013 14:56:46 GMT
There are also a bunch of connectors tucked high up inside the n/s A panel (remove the trim)
Post by fragile on Dec 31, 2013 8:57:20 GMT
Thanks for ideas guys John, i did find the connectors in foot well front passenger side and all seemed well. I cant find any in rear passenger side, are these in boot behind tank, or under seat, i have looked but not ripped every thing apart yet. Any more pointers Neil
Post by Phil Nottingham on Dec 31, 2013 9:13:19 GMT
Right up underneath the parcel shelf above the tank - access by removing boot tank trim board
Post by fragile on Dec 31, 2013 9:22:21 GMT
Thanks Neil
