Post by jeffbarnes49 on Jan 26, 2014 19:01:46 GMT
hi can any one help please my 1970 p5b coupe had no fuse board I have replaced this but unsure of correct cable positions so has any one got a diagram of fuse box area wires showing what goes wear on both sides or a picture and colours or any ideas that would help thanks
Post by johnwp5bcoupe on Jan 26, 2014 19:34:56 GMT
This may help Jeff? the Purple wire dangling is for the under Bonnet Lamps
Post by Phil Nottingham on Jan 26, 2014 19:36:36 GMT
Club members can have a free coloured diagram. Otherwise full details are in the handbook and workshop manual; These are also available from the club at good prices
Post by enigmas on Jan 27, 2014 23:50:11 GMT
That's one pristine 'loom' John ...nothing like my original one.
Post by johnwp5bcoupe on Jan 28, 2014 6:39:18 GMT
That's one pristine 'loom' John ...nothing like my original one. Cheers Bud
Post by djm16 on Jan 29, 2014 0:24:11 GMT
Is the fuse array above supposed to have some kind of cover over it?
Post by Warwick on Jan 29, 2014 5:21:07 GMT
The black part with the writing on it is the cover. The fuses are covered but the spade connectors of the loom are exposed, but insulated (mostly).
Post by Simon H on Jan 29, 2014 18:18:48 GMT
I'm going to be fitting some relays to run the halogen lights I'm installing. I hope to tap into the fuse rail (as pictured above) to pick up feeds to switch the relays. Is that a practical idea? Which side of the fuse rail is the feed i.e. un-fused side?
Cheers Simon H
Post by Phil Nottingham on Jan 29, 2014 19:52:10 GMT
The Brown cables ie LHS - they are quite suitable for pickup feeds
Post by Simon H on Jan 29, 2014 20:13:09 GMT
So, if I disconnect the wire at Terminal 24 could I use Terminal 24 as the switching signal for the fog light relay and use the wire that was on T24 to feed the fogs from the relay? And pick up from T1 to feed the fused relay? I realise that the dip and main beam will be more complicated...
Simon H
Post by Phil Nottingham on Jan 29, 2014 23:47:38 GMT
Yes
