Post by Deleted on Sept 24, 2006 17:34:15 GMT
HI All, I have picked up my P5B and overall it is not too bad. It has been partly restored with the engine and gearbox being replaced. The problem I have is not all the pipes are connected on the engine and gearbox. If you go to the following website www.m535i.co.uk/rover_p5b.htmYou will see the pics of the pipes (Click on the image to enlarge). I do not know how they should be connected any help would be great. Many Thanks David
Post by harvey on Sept 24, 2006 18:22:48 GMT
Hi there, Pic 1, only used if the car is still fitted with an AED.
Pic 2, swap the air cleaner elbows over and fit a 90 degree hose between the pipes.
Pic 3, there should be a hose from the air filter housing to a fuel filter (engine breather) in a bracket on the rear of the inlet manifold, and then to a pipe from the rear of the block
Pic 4, if that's by the gearbox that looks like disconnected fuel or gearbox cooler pipes.
Hope this is of some help
PS keep that bloke with his blue paint away from it in the future! Good luck with your new purchase.
Post by Smallfry on Sept 25, 2006 0:02:01 GMT
Picture 4 That nylon pipe looks like it has a good sized hole in it too ?
Post by Deleted on Sept 25, 2006 17:31:03 GMT
Thanks for your help I shall investigate at the weekend.
David
Post by Deleted on Nov 6, 2007 20:13:57 GMT
hi mate just tried to get on the web page but it wont have it my p5 is the same when i picked it up and i was wondering the same thing HI All, I have picked up my P5B and overall it is not too bad. It has been partly restored with the engine and gearbox being replaced. The problem I have is not all the pipes are connected on the engine and gearbox. If you go to the following website www.m535i.co.uk/rover_p5b.htmYou will see the pics of the pipes (Click on the image to enlarge). I do not know how they should be connected any help would be great. Many Thanks David
Post by dorsetflyer on Nov 7, 2007 15:18:04 GMT
It could well be that the pics have been deleted from the website, and so on-one can access them .
