Post by petervdvelde on Jan 6, 2007 21:26:48 GMT
Hello, I am new in the P5B world. I bought a P5B Coupe and have covered 1500 miles in the first month i own it. Its great fun. As i have children, i would like to install seat belts on the rear seats. Anyone has experience installing these? Thanks Regards Peter.
Post by Phil Nottingham on Jan 6, 2007 22:13:50 GMT
Try SEARCH set for 600 days?
Post by petervdvelde on Jan 6, 2007 23:49:16 GMT
Thanks Phil,
Did the search and there was 1 other owner thinking about fitting the rear ones. No other messages. Regards Peter
Post by Deleted on Jan 7, 2007 11:34:23 GMT
Check out
FDTS Ltd Highfield Works West Byfleet Corner West Byfleet KT14 6LP(Road Map) Surrey Tel: 01932 342043
This company can help with any spec. or type of seat belts and can offer a wide choice of coloured wbbing if required. They can also offer classic style buckles and can offer all types of bolts, eye bolts, buckles and fittings.
I am just a satisfied customer of theirs, no other connection.
Freddy
Post by Multi-Tech on Jan 7, 2007 13:54:16 GMT
I have also used FDTS a few times and they are very good and not bad on price, again just a happy customer ;D
Post by RichardF on Jan 8, 2007 19:23:32 GMT
Peter, I have just received my two rear seat belts from Europa: www.europaspares.comThey are of the type that fit on the rear parcel shelf using the originally fitted anchor points already in place. They lay flat due to an adjustment on them that also allows for them to be used in pillarless coupes. Cost was £53.76 each plus p&p, plus vat. I plumbed for the beige colour to match my fronts (also from Europa). I have not fitted them yet but it really looks to be easy enough. The hardest bit will be making a neat hole in the rear parcel shelf finisher. JR Wadhams also sell them - in various colours aswell. As my car is semi stripped on the inside, I can take some photos if you like and send them yto you via e-mail. Regards Richard Southampton
Post by petervdvelde on Jan 8, 2007 20:15:51 GMT
Thanks all for your reactions. Richard, i am very interested in your pictures. My e-mailadress is p-velde@iae.nl. Regards Peter
Post by RichardF on Jan 9, 2007 18:54:44 GMT
Peter,
I have just sent you three sets of photos of the rear seat belt attachments (18:50 UK time).
Regards
Richard Southampton
Post by petervdvelde on Jan 12, 2007 12:07:00 GMT
Hello Richard,
Thank you very much for the very clear pictures. With all the mounting points more or less readily available its not a very difficult job
I need some other parts for my p5 so i think i will contact Wadhams. Thanks again Regards Peter
10mpg
Post by 10mpg on Jan 30, 2007 21:25:34 GMT
I have a set fiited in my saloon, black aftermarket type tho but as i have black origional ones in the front aswell they at least match!
What colour is your interior as i may have some light beigy coloured ones (match the cream leather seats), i have had them for a while for no particular reason if i havn't thrown them out when i moved (which is a possibility) you would be welcome to them...
Guus
Post by Guus on Mar 28, 2007 14:21:53 GMT
I had a set fitted when I bought the car, but I am not all too happy with them: they look very plumb on the rearshelf en ofted block when trying to use them! Perhaps I had better fitted a pair of 'modern' belts...
Post by p5tgc on Mar 29, 2007 9:32:41 GMT
RichardF: Could you post the pictures on this site so we can all see? Could you also give the Europa part number? Many thanks.
Post by RichardF on Mar 31, 2007 19:45:48 GMT
Apologies for late response. Car problems plus a multitude of other things to sort. Europa part number is: 514/30 - I chose beige to match the interior and the front seat belts. The belts I have quoted are fronts for pillarless coupes and the like but, looking at the inertia reel itself, it can be angled to suit, hence will fit on the rear shelf and my reason for buying them. I have yet to fit them I am ashamed to say simply due to pressure of work and commitments. J.R. Wadhams also sell belts for the rear and I believe in various colours. As for posting pictures here, I'll have to gen up on how to do it and also time permitting. Richard Southampton
Post by Deleted on Jul 12, 2007 13:50:23 GMT
I am trying to fit rear seat belts. I have bought beige ones from Wadhams. but have no idea where the anchorage points are. I have not been able to download (find) pictures from the forum Any help please? Martyn mandl@mandlmorris.wanadoo.co.uk
Post by Phil Nottingham on Jul 12, 2007 16:06:16 GMT
Only the wheel arch and centre ones are fitted - they may have been left out in body repairs - the wheel arch ones can be seen from outside the car just about 62 up from the bottom of the sill
Post by Deleted on Jul 12, 2007 16:28:56 GMT
Not sure how to contact everyone but where are the fixing points?
Post by Phil Nottingham on Jul 12, 2007 16:57:22 GMT
See earlier post??
PS The underseat points are just aside the top of the centre transmission tunnel. All the mounting points should have a large pastic bung in them with a X recess like a Phillips screw.
The parcel shelf ones have to be drilled and plated to suit the belt/reel case
Post by RichardF on Jul 14, 2007 16:15:42 GMT
I have now fitted my rear seat belts. I had to drill approx 2" further back from the original mounts (already there with strengthening plates). Also, because of the thickness of the rear parcel shelf, I made up some spacers to suit from steel tubing and then anchored the long bolts from inside the boot using strengthening spreader steel plate and a stiff nut for each side. I deliberately allow the "rewinder unit" to swivel slightly on the parcel shelf so that at rest it is straight down the seat and when worn by an occupant in the seat, rotates to allow the diagonal across the torso. The fiddly part for me was finding "right-angle" mounts for the centre bits as they are completely straight in design at the anchor points and come out just either side of the centre arm rest. Richard Southampton
Post by Deleted on Sept 4, 2007 21:44:16 GMT
Hello Peter I had rear seat belts in my coupe but took them out because they did'nt look right and were a bit hit and miss when you came to use them.For instance last year when the car went for an mot they started playing up AGAIN!! and the guy at the mot garage said if you don't get them to work i will have to fail the cars mot.So after an hour of fiddling with them and getting them to work he avenchually passed it.As far as the anchor piont,from what i can remember, they were bolted in the very corner of the rear parcel shelf, drilled through the metal and bolted.Hope this helps. Phil
