Post by Deleted on Jan 20, 2007 19:20:46 GMT
Hi all. well got round to doing my electronic fuel pump. Also changed the prop shaft mounts (fun job not) The fuel pump has made loads of difference the old pump arm was very warn and was leaking oil so killed to birds with one stone there. getting there slowley but i have a list as long as my arm to do to her. ;D
Post by Multi-Tech on Jan 21, 2007 15:40:19 GMT
Keep up the work Tony, Whats next?
Post by johnwp5bcoupe on Jan 21, 2007 21:02:11 GMT
NEVER make a list of things to it's fatal just keep plodding on
Post by Deleted on Jan 21, 2007 23:14:11 GMT
what to do nexe.........re spray really but trying to find someone to do a good job with out using loads of filler which hard. im taking it to a place not far from me this week to get a price.
Wish me luck
Post by Multi-Tech on Jan 22, 2007 18:46:55 GMT
One body shop which we do work for in woking is the dogs *** but i do know you pay for what you get. Give them a call i have seen there work and its spot on will be taking mine there ;D ambassadorcoachworks.co.uk/
Post by mancamefirst on Jan 23, 2007 15:58:53 GMT
Good Luck Tony Let us know how you get on
Post by Deleted on Jan 29, 2007 20:56:04 GMT
hi all. not used the rover since doing the prop shaft mounts. Took her out today for a quick spin and the is a very bad virbraction coming from the prop shaft Its really bad at 30mph to 45mph. I had a look underneath and all is tight and where it should be.
All the old bushes were broken so im wondering if the prop is out of balance or something which caused the bushes to bake in the 1st place???
Anyone els come across this before??
Post by Phil Nottingham on Jan 29, 2007 21:50:12 GMT
More likley a seized UJ joint - disconnect each one, start at the axle and check they are free to swivel without any tight spots or sloppiness
Post by Deleted on Jan 29, 2007 22:51:57 GMT
cool didnt think about that. another job on the list to do ASAP then.
Thanx phil
Post by Deleted on Sept 2, 2007 8:42:36 GMT
I have exactly the same problem. I have found adodgy uv joint in the middle and hope to replace it. Not sure whether the judder was caused by it or the judder cause the joint to collapse. Never fitted uv joint before so here goes !! mandl@mandlmorris.wanadoo.co.uk Martyn
theroveringmember
Post by theroveringmember on Sept 3, 2007 1:56:52 GMT
Just got the 2200TC back on the road with her temporary 2000SC installed (& a very nice gearbox pleasingly) & theres an annoying rythmic squeak which could be a UJ. Have to check that out.
