Post by petervdvelde on Sept 10, 2007 20:46:53 GMT
Hello, I started the restoration on my P5B Coupe and have a spare subframe with all suspesion, wheel and brake components and want to get this powdercoated. I can still use my car in this way. I checked the subframe dimensions with the dimensions in the manual and found some differences. The manual only shows the P5 subframe. The spare frame stayed in an open field for some time and has some dents which should be reparabel. Checking the frame i found that the left enginemount sits approx 5mm higher and 5 mm more backwards then the rh enginemount. I assume and see that the rh enginemount is bended a little which explains the 5mm less backwards. The hight difference i cannot explain but i assume this will not cause much problems. Can somebody confirm that there should be no difference in the horizontal position of the enginemount. Also the manual says the dimension L should be 1783mm but i only measure on both sides 1715mm. Anybody noticed this? I attached the subframe drawing and some pictures. Thanks in advance Regards Peter i226.photobucket.com/albums/dd310/petervdvelde/2007_0731Image0039.jpgi226.photobucket.com/albums/dd310/petervdvelde/2007_0731Image0042.jpgi226.photobucket.com/albums/dd310/petervdvelde/chassisp5b-adj2049.jpg
Post by Phil Nottingham on Sept 10, 2007 21:07:53 GMT
It's not something I ever measured - however I have an engine less P5B standing outside (still) so when it light tomorrow I will check this.
The front end often gets damaged in shunts - it can spread back to the rear cross member mounts if these are rust weakened
Post by petervdvelde on Sept 11, 2007 21:08:30 GMT
Post by Phil Nottingham on Sept 11, 2007 21:49:46 GMT
Interesting - I have never inside a relatively rustless one. How many Dremel discs did you use!! Ps Forgot to take the measurements! Will try to remember tomorrow
Post by petervdvelde on Sept 12, 2007 10:41:04 GMT
Phil,
I was also surprised only finding surface rust inside the sub frame a it lay in an open field more or less covered by plants I used approx 15 discs but only half of them were fully used. The other half broke before i could fully use them. However its amazing what one can dot with such a fragile disc and i really like these Dremels
You would really help me with the measurement but it could wait untill the weekend. Regards Peter
Post by Phil Nottingham on Sept 13, 2007 19:19:31 GMT
I have carefully measured the mounts on mine from a variety of positions and conclude that they are meant to the same height and distance. It may be that your subframe is slightly twisted. Whether this is in tolerance I am not sure though but 5mm in such a component may not be a real problem
Post by petervdvelde on Sept 14, 2007 19:49:21 GMT
Hello Phil,
Thanks for checking. I think hte difference in height is not a problem. The difference in horizontal position is caused by the actual motor mount which is welded on the tube and this can be put at the right dimension rather easy. Regards Peter
