Post by Deleted on Oct 12, 2007 21:40:36 GMT
Hi all is the lucas part No for a p5b starter motor LRS318
Post by Phil Nottingham on Oct 12, 2007 21:58:43 GMT
No idea - several types were fitted - some late one do not have the ballast shunt on the solenoid cap if one is needed
Post by Deleted on Oct 12, 2007 22:14:39 GMT
Mine has got the ballast shunt
Post by Phil Nottingham on Oct 12, 2007 22:26:09 GMT
Make sure the replacement one has this extra terminal then as its awkward to do without it unless you dispense with the ballast and fit a standard sports coil as its not really required and mine starts easily in the coldest of weathers.
Some solenoid caps have a blob of solder to whaich a cable or terminal can be carefully soldered. This only become live when the motor is activated so bypassing the ballast and supplying the full 12v to the 9 or 6 volt coil
