Post by Deleted on Nov 18, 2007 8:11:46 GMT
Phil,you mentioned that the rubber had worn off my accelerator pedal and I would have to make a new one. Was this part ever availible or is this a common fix for rover owner s if so I'd appreciate anyone else's solution to this problem. cheers . scarlettwill
Post by Phil Nottingham on Nov 18, 2007 10:39:52 GMT
It would have been available but certainly not now - its usual to get a better one from DG
Post by Deleted on Nov 18, 2007 10:59:41 GMT
nice one Phil , prompt and precise as usual!
Post by Deleted on Nov 22, 2007 8:01:26 GMT
I emailed david green £10. plus postage if hes got one but...I've had an idea! A mild steel door hinge slightly modified could be bolted or welded in place to the floor pan than riveted to the bottom of the pedal , what do you guys think? 'm looking at this from a builders point of view some of you might have a better idea. Scarlettwill
Post by Phil Nottingham on Nov 22, 2007 18:01:32 GMT
I think I suggested this once on some earlier post!
Post by Deleted on Nov 22, 2007 20:34:46 GMT
Great mind's think alike .. but donkeys seldom differ ;D Thats what my old primary school teacher Mrs Macintosh used to say when she caught me cheating!
