Post by Eric R on May 27, 2015 15:15:31 GMT
Having re-painted the boot i find that the boot decal wont hold tight to the paintwork. It appears that there a some tiny plastic plugs to be inserted in the boot in order that the lugs on the lettering can wedge in tightly, perhaps like a rawl plug in a hollow panel. National inquiries have failed to find these and i don't want to glue them in just in case it needs to be removed again in the future. Not illustrated in the parts or how-to manuals. The Mk1 badge is one slim piece, not the chunky ones in later P5Bs
Post by johnwp5bcoupe on May 27, 2015 16:19:32 GMT
Having re-painted the boot i find that the boot decal wont hold tight to the paintwork. It appears that there a some tiny plastic plugs to be inserted in the boot in order that the lugs on the lettering can wedge in tightly, perhaps like a rawl plug in a hollow panel. National inquiries have failed to find these and i don't want to glue them in just in case it needs to be removed again in the future. Not illustrated in the parts or how-to manuals. The Mk1 badge is one slim piece, not the chunky ones in later P5Bs Have a look here Eric Badge Fixings
Post by enigmas on May 28, 2015 1:21:43 GMT
Thanks for the link John...I also need some of the clips listed. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by johnwp5bcoupe on May 28, 2015 5:56:12 GMT
Thanks for the link John...I also need some of the clips listed. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Pleased to help Vince ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Post by guidedog on May 29, 2015 8:31:09 GMT
JRW do the plastic inserts. But he's on holiday again.
Post by Eric R on May 31, 2015 14:01:56 GMT
I don't know if my P5 3-litre is that peculiar, but i don't see the part on JRW website so i will have to phone him on his return. The Bresco link kindly supplied shows quite a few but I guess the badge will need to be removed again to determine the hole diameters. I have now found a reference in the parts catalogue p326/7 which states part 56 to be the name plate but then describes four plain and spring washers and UNC nuts which suggests a bolts. I don't see any thread on the nibs that I can view from the outside. Any internal fixing is not visible because of the boot reinforcing bars and cant therefore be applied! C'est la vie!
Post by Eric R on Jun 8, 2015 19:04:39 GMT
Advised to ignore the parts book which shows 4 nuts/spring washers. My man popped the 3 lugs through the holes and offered up small spring washers on the end of a socket spanner - job done. My thanks to those who showed an interest in this problem.
Post by Norse Blue on Jul 23, 2015 22:42:54 GMT
Having re-painted the boot i find that the boot decal wont hold tight to the paintwork. It appears that there a some tiny plastic plugs to be inserted in the boot in order that the lugs on the lettering can wedge in tightly, perhaps like a rawl plug in a hollow panel. National inquiries have failed to find these and i don't want to glue them in just in case it needs to be removed again in the future. Not illustrated in the parts or how-to manuals. The Mk1 badge is one slim piece, not the chunky ones in later P5Bs Hi Eric. You can get these 'plugs' from .... www.scottsoldautorubber.com.au/Rover%20P5%20P5B%203litre%203.5litre.htmCheers Anthony
Post by Chuck Berry on Oct 12, 2016 16:58:27 GMT
I needed the full set for "Coupe", "Automatic" and "Rover" JRW sells thems a set for each use and they are not that expensive.
Post by johnwp5bcoupe on Oct 12, 2016 18:27:41 GMT
Try BRESCO do all sorts inc what you need BRESCO
