Post by theroveringmember on Dec 9, 2007 7:00:40 GMT
Whew!... That's nasty. Hopefully the car hasn't distorted. Once again I post this reply to offer some hope & encouragment. That frame is obviously well beyond saving but good secondhand ones are reasonably straightforward to obtain in my experience.
Yes it (subframe replacement) was pretty straight-forward, not least as we're renting a nice workshop (well, nice to me. at the moment. Took the interior out to reduce weight (the front seats weigh a ton), disconnected gearbox rods, fuel & reserve, propshaft from inside the car. Once all connections under the bonnet disconnected (you have the pull the steering column into car too, not hard), I slung a rope around the front valance (through the holes & over the top) & lifted the car away from the subframe assembly with my engine hoist then supported the body on a plank resting on ramps, under the jacking points. As the hoist was in front of the car it was hard work dragging it out the side but when I put it back I lifted the car & supported it on the sills (a really big pair of axle stands under the jack points would have made this easier), then lined the assembly up in front & put the hoist back in place under the subframe. Much easier though of course, you must be confident in the strength of your sills. It's a bit nerve-racking but we replaced mine when the car was restored. Lowering the car onto the frame was surprisingly easy & the bolt-holes lined up nicely. Don't tighten any bolts until they're all started, leave it loose so you can still raise/lower the body which I had to do to get the last bolt started. When you raise/lower, don't put the rope under the bottom of the front valance as it will bend under the weight.....as mine did when I replaced the frame. Don't know why I did it wrong the second time. I think the expression is....Doh! ;D
The benefits of access with the frame out are obvious even if you don't need to change it. Space & shelter is the name of the game I think, unless you've got nice weather & I did the whole job myself so it's perfectly possible.
