Post by cstorey on Aug 29, 2015 12:07:54 GMT
I now have a new Scott's coupe rear rubber, but I cannot for the life of me see which way the profile fits onto a .the screen and b.the body surround . Please does anyone have a pic which shows the correct orientation ? Edit : I am now wondering whether the earlier fitment was inside out/wrong way round , as I am told can happen ? ![](http://i840.photobucket.com/albums/zz323/christopherstorey/P1100197_zpssoobatn5.jpg) ![](http://i840.photobucket.com/albums/zz323/christopherstorey/P1100195_zpsys4utejn.jpg) ![](http://i840.photobucket.com/albums/zz323/christopherstorey/P1100201_zpsorbo43ec.jpg)
Post by johnwp5bcoupe on Aug 29, 2015 15:38:12 GMT
You really can't go wrong if the screen is in the deepest section/groove in the seal the lip on the inside is the smaller of the two, have you managed to get the inside lip to fit snugly on the inside of the screen opening?
Post by cstorey on Aug 29, 2015 16:16:29 GMT
John : thank you - I have taken the plunge and installed it like this - which seems to correspond with the drawing in the workshop manual - but as yet the interior seal is untidy particularly at the corners ![](http://i840.photobucket.com/albums/zz323/christopherstorey/P1100202_zpsx1url49w.jpg) Is this correct ?
Post by johnwp5bcoupe on Aug 29, 2015 19:15:02 GMT
It looks correct you really have to do a lot of pushing and pulling!!
Post by cstorey on Aug 29, 2015 21:23:02 GMT
John : Many thanks . I am going to let it settle over the next day or two and then give it a good few pushes, shoves and bangs with the flat of the hand . The outside seems fine but the inner face is sticking out horizontally on a high proportion of the surround . I had not realised until I tried it that , unlike the majority of installations, the screen really only lies in the channel rather than having the seal being wrapped over the lip of the bodyshell to secure it ( and it still looks as though it is really only secured to the shell at the bottom of the screen , the upper clips serving apparently only to secure the stainless trims )
Post by johnwp5bcoupe on Aug 30, 2015 5:31:30 GMT
John : Many thanks . I am going to let it settle over the next day or two and then give it a good few pushes, shoves and bangs with the flat of the hand . The outside seems fine but the inner face is sticking out horizontally on a high proportion of the surround . I had not realised until I tried it that , unlike the majority of installations, the screen really only lies in the channel rather than having the seal being wrapped over the lip of the bodyshell to secure it ( and it still looks as though it is really only secured to the shell at the bottom of the screen , the upper clips serving apparently only to secure the stainless trims ) You will get there ![;)](//storage.proboards.com/forum/images/smiley/wink.png) the inner lip should lie flush with the body it is really a case of manipulating the rubber, I have done a few Scotts seals and they do go in, just make sure the rubber is fitted in VERY warm conditions otherwise you will struggle! and don't forget to pack it well with DumDum or whatever is supposed to be the equivalent?
Post by cstorey on Sept 7, 2015 17:44:45 GMT
Thanks to all who helped, including Scott from Australia . Job now done and , as far as I can tell , no leaks !
frans
Post by frans on Mar 11, 2016 11:46:49 GMT
Hello,
Can you tell me where to buy screen rubbers for the front and rear screen for my P5 MKI 1961?
Thanks
Frans
Post by cstorey on Mar 11, 2016 14:03:49 GMT
David Green here in England sells them ( search for him on this board ) , or you could order them direct from Scott's Auto Rubbers in Australia
Post by davidg on Mar 11, 2016 21:16:34 GMT
Frans,
I have them here in stock.
David
frans
Post by frans on Mar 13, 2016 14:42:45 GMT
David,
That's great! Front/rear for P5 MKI Saloon 1961? If so, I worded them immediately. Please advise price, delivery and method of payment.
Many thanks Frans
