Post by lencottam on Feb 28, 2008 16:10:26 GMT
I FOUND THE CIRCUIT FOR USING A BRIDGE RECTIFIER,ON THE V8 REGISTER WORKSHOP NOTES 320,IF ANYONE IS INTERESTED.THE MOD WAS VERY CHEAP TO DO
Post by johnwp5bcoupe on Feb 28, 2008 16:59:27 GMT
I think we dealt with this before Len " have had a look at the circuit you could put a diode (5 amp one to be safe) from C2 on the start relay to the connection point that goes to the starter after disconnecting the offending circuit at the balast resistor the -ve side would have to go to C2 otherwise the current will not flow you will get 0.7v drop accross the diode "
