Post by landcrab on Mar 9, 2016 3:46:26 GMT
On my P5, the temperture gauges reads high, and the fuel gauge show empty even when tank full, any ideas Also does anone know the resistance of the senders for these gauges (max to min) so that I can test the gauges Cheers Peter
Post by p5rover on Mar 9, 2016 7:54:13 GMT
I had a problem with my fuel and temp gauges, they would read higher the faster the engine was spinning. Turned out to be the voltage stabilizer behind the dash/gauges.
Post by johnwp5bcoupe on Mar 9, 2016 9:52:44 GMT
On my P5, the temperture gauges reads high, and the fuel gauge show empty even when tank full, any ideas Also does anone know the resistance of the senders for these gauges (max to min) so that I can test the gauges Cheers Peter From memory 0-90 ohms this problem is a common one short the Green and Black wire to chassis see what you get?
