Post by daveh on Apr 2, 2016 20:26:17 GMT
i need festoon bulbs for the courtesy lights inside my mk1a p5 i have found them on a website but it does'nt specify car models and they have seven different sizes in MM sizes am i right in thinking these sizes are for the bulb length [cap to cap]? these are the bulb sizes on the shop site
269 (31mm) 269 (31mm) 272 (36mm) 272 (36mm) 239 (38mm) C5W 239 (38mm) C5W 272 (38mm) C10W 265 (44mm)
or does anyone know the size to order, so i can be sure to order the correct item,i broke one after taking the trim down to install new furflex.that is now part done. i have never seen as many tacks in my life.
Post by Phil Nottingham on Apr 2, 2016 21:14:52 GMT
I prefer LEDS these days for the lights - but from memory its 38mm. but easy to get hold of in old style tungstone
Will check tomorrow
Post by djm16 on Apr 2, 2016 22:31:30 GMT
Post by petervdvelde on Apr 2, 2016 23:12:16 GMT
Some MGB's have the same courtesy lights so you could check with Moss, Brown and Gammons or other MGB part suppliers
Post by daveh on Apr 3, 2016 17:14:16 GMT
thanks all for your input, it's my own fault as usual i was a bit heavy handed taking down the head lining trim strip above the doors, and i broke the bulb i just dumped the bulb and then with very little info on the shop site, i was unsure on the size required, i made sure when i started on the nearside that i did'nt do the same
Post by Deleted on Apr 3, 2016 20:55:00 GMT
On a similar subject, has anyone tried LEDs in place of the bulbs that illuminate the writing around the switches?. I find they are pretty hopeless at night and the labels might as well be in Serbo Croat for all the help they are in identifying the switches.
Post by barryr on Apr 3, 2016 21:30:42 GMT
I never even knew the switches lit up !
Post by Deleted on Apr 4, 2016 10:06:31 GMT
They do,honest. Trying to work out what does what at night (you can guess I dont drive mine that often at night,or during the day come to that) is lots of fun. Jumping from one car to another often results in pressing the wrong controls (well,it does for me anyway) yesterday in the taxi,I got cut up on a main road and gave the culprit a dam good squirt of the windscreen washers.
Post by djm16 on Apr 4, 2016 11:24:48 GMT
No, as there are 4 of them and they are a bit small and fiddly to modify, however I have modified the speedo and tach illumination to take 1w LEDs (home made for +ve earth).
Post by gingerbeer62 on Apr 4, 2016 14:27:54 GMT
On a similar subject, has anyone tried LEDs in place of the bulbs that illuminate the writing around the switches?. I find they are pretty hopeless at night and the labels might as well be in Serbo Croat for all the help they are in identifying the switches. I did mine a while ago. Recommended. I also bought some courtesy led bulbs but didn't like them as too white. Dash is great though Cheers Colin roverp5.proboards.com/attachment/download/1232
Post by gingerbeer62 on Apr 4, 2016 17:04:45 GMT
They do,honest. Trying to work out what does what at night (you can guess I dont drive mine that often at night,or during the day come to that) is lots of fun. Jumping from one car to another often results in pressing the wrong controls (well,it does for me anyway) yesterday in the taxi,I got cut up on a main road and gave the culprit a dam good squirt of the windscreen washers. Very Good - Very Good ! Nice to have a laugh. I have a Ford Scorpio as well and am forever getting mixed up with the indicators as on opposite side to the Rover. I also reach to the wrong side of the steering to start either car. Cheers Colin
Post by Deleted on Apr 4, 2016 19:45:11 GMT
Thanks for the pic,the speedo and rev counter look far better with the LEDs. I did take the rheostst switch apart and cleaned up the contacts which has helped a bit.I like a nice bright dashboard at night so I'll have a go at converting the bulbs/holders on mine. Or,I could just print off your picture and stick it over my dash.
Post by gingerbeer62 on Apr 4, 2016 19:53:46 GMT
Thanks for the pic,the speedo and rev counter look far better with the LEDs. I did take the rheostst switch apart and cleaned up the contacts which has helped a bit.I like a nice bright dashboard at night so I'll have a go at converting the bulbs/holders on mine. Or,I could just print off your picture and stick it over my dash. If it's any help the thread is here roverp5.proboards.com/thread/9314/ledsCheers Colin
