frans
Post by frans on Aug 10, 2016 18:56:28 GMT
Hi, I have a MK I, 1961, with a electronic 123-ignition fitted. I have not driven much with the car since I own it. After driving a while the engine is misfiring and I suspect that something is wrong with the electronic ignition. Therefore i am checkingthe wiring, connections and settings. I have already fitted Silicon cables. Now I wanted to check the proper firing order. Strange enough I don't find this in the workshop manual! Can anyone tell me the firing order starting at the TDC? I have read the thread about the cables and the problems of overheating of the coil. Could it be problem that the coil has not the correct resistance? The car is fitted with an AC Alternator and changed to negative earth. Suggestions welcome! Thanks Frans
Post by Phil Nottingham on Aug 10, 2016 19:23:45 GMT
frans
Post by frans on Aug 14, 2016 12:50:37 GMT
Hi Phil, Thanks for the answer. Being a Rover P5 bloody beginner, may I ask this question: in the workshop manual is noted that the distributor rotates in clockwise direction. Therefore, if the firing order is 1-5-3-6-2-4 and looking from top on the distributor cap the wires should be connected staring at 1 going clockwise 5-3-6-2-4, right? If I look on the top of my distributor cap the wires are connected in clockwise direction 1-4-2-6-3-5 (as delivered from the shop who fitted the electronic ignition)!!! What is correct??? The engine runs, but once in a while the firing is irregularly and the engine bounces! Your advice appreciated! Frans
Post by Phil Nottingham on Aug 14, 2016 19:19:00 GMT
The distributor rotates anticlockwise on 3 Litres - Clockwise on 3.5 Litres
frans
Post by frans on Aug 14, 2016 19:32:48 GMT
Wow! This conterdicts with the Mark I Wirkshop Manual! Anyway, many thanks fior the information! Frans
frans
Post by frans on Aug 21, 2016 12:57:42 GMT
I am preparing to check and adjust the ignition timing. For this I need the TDC timing marks on the flywheel, which are behind a cover on the flywheel housing. Can anyone tell me where to look for this cover? Is it accessible from the top or from underneath the car (in which case I would need a pit or so)? Frans
Post by Phil Nottingham on Aug 21, 2016 17:47:59 GMT
Looking from FRONT of the car its on the left side of top of the bellhousing near the bulkhead. It hard to see - loosen the 7/16" AF nuts only and swing aside
frans
Post by frans on Aug 21, 2016 20:13:53 GMT
John, Many thanks for the answer. Even though I owned a p5 1960 46 years ago I never worked on one before. Now I own a p5 1961 and slowly need to find my around. This explains my many basic questions! Thanks! Frans
frans
Post by frans on Aug 21, 2016 20:14:48 GMT
Sorry, Phil!!!
Post by Phil Nottingham on Aug 21, 2016 20:43:52 GMT
Mk2 but same place (same as P2, P3 and P4 as well
Post by harvey on Aug 21, 2016 21:03:54 GMT
Mk2 but same place (same as P2, P3 and P4 as well And P6.
