Post by anglia105 on Aug 24, 2016 11:41:17 GMT
Hi. I know it's not just me with one of these on a p5b . There was fuel coming out of the pressure regulator so I ordered a new one from eBay ......new one leaks as well ! Can anyone who's running this carb tell me what fuel pump and regulator they are using ? Thanks Steve
Post by guidedog on Aug 24, 2016 13:27:46 GMT
Hi 105
I have an Edelbrock carb on my P5B as yet No problems. What fuel pump are you using? these carbs can handle up to 6lbs per sq. inch. The pump you require is a Facet solid state I am using a 4.0-7.0 Psi which is border line usage if you use the lower rated model 3.5-5.0 Psi that will ok. I have no regulator fitted. Merlin Motor Sport have a range of pumps.
Post by anglia105 on Aug 24, 2016 13:32:43 GMT
Thanks for the reply. I'm digging the car out of storage at the end of the week I'm going to check what pump is fitted. I was surprised it had a regulator at all.
Post by wozzer on Aug 24, 2016 18:10:37 GMT
Hi 105 I run a similar set up but i use a faset silver top pump and a filter king filter/regulator with gauge, Works great and you can obviously increase/decrease fuel pressure Woz
