dt
Post by dt on Nov 6, 2016 23:44:44 GMT
Sorry if this is an obvious question! Rear passenger moulding fell off today when my partner was a little over enthusiastic on shutting the door. Can anyone tell me how these are refitted? I notice that there are couple of tabs, one of which is highlighted below. Does the chrome strip fit into these? It seems not to want to do this, however, I haven't tried too hard to do this. Does it also fit on the top of the door or just in the tabs? Many thanks! Attachment Deleted
Post by johnwp5bcoupe on Nov 7, 2016 10:06:37 GMT
There are clips on the trim that clip on the top of the door edge can be a bit tricky to fit!
dt
Post by dt on Nov 7, 2016 10:25:43 GMT
Post by Phil Nottingham on Nov 7, 2016 17:39:41 GMT
Full details on SEARCH
dt
Post by dt on Nov 7, 2016 21:11:59 GMT
dt
Post by dt on Nov 8, 2016 13:40:41 GMT
Many thanks successfully refitted, a little bit of knowledge goes a long way!
Post by Phil Nottingham on Nov 8, 2016 18:14:42 GMT
Precisely - many little bits make up the hole - a lot but not all are in the WSM which is not absolutely essential if you want to do more than open the drivers door ![;)](//storage.proboards.com/forum/images/smiley/wink.png) It is is still essential however to look after a quality car in the manner expected by Rover
