Post by norvin on Dec 1, 2012 20:18:44 GMT
Thanks for a full answer John, good news about the head bolts only needing oil.
Post by eightofthem (Andy) on Dec 1, 2012 21:01:50 GMT
I used just engine oil,no problems here.
Post by johnwp5bcoupe on Jan 25, 2013 21:54:56 GMT
Finally I have my Manifold back I found a great enthusiastic guy in Norfolk this after the other "B" lot ruined the job for the 4th time! lucky David Cole had the correct year manifold stamped 1969 I did get one from David Green but it was slightly later. The finish is perfect "not Polyester" done in Acrylic Lacquer totally solvent resistant So I can start putting the inlet side back together the Exhaust Manifolds will be with me on Monday so I hope by the end of the week to hear The Old Girl burble again The little 10 X UNC were "B's" to make that's the ones on the Blanking Plate both pipes on the Bridge are also SS as are the Spigots for the Air Filter. I made new Bronze Bushes for the Carb Linkage so it should all last a while
Post by eightofthem (Andy) on Jan 25, 2013 22:06:22 GMT
Very nice job, you will have to wear these when you lift the bonnet. Whats next?
Post by johnwp5bcoupe on Jan 25, 2013 22:27:15 GMT
Fit it in the morning Andy
Post by johnwp5bcoupe on Jan 26, 2013 19:04:10 GMT
Post by eightofthem (Andy) on Jan 26, 2013 20:25:18 GMT
Nice You should have been a surgeon.
Post by johnwp5bcoupe on Jan 26, 2013 22:03:55 GMT
Thanks Andy I thought you were the one dissecting a BW35
Post by johnwp5bcoupe on Jan 27, 2013 16:19:08 GMT
Post by barryr on Jan 27, 2013 22:52:00 GMT
Looks fab!,
Did you mask off the covers for coating or sand through the coating on the fins and rover part?
It's going to look brilliant all back together.
Post by johnwp5bcoupe on Jan 28, 2013 7:01:04 GMT
I cut through the PC Barry an it honestly took the best part of the day I thought 400 then 600 wet and dry but the lacquer was so good/hard it was very difficult to cut through! I didn't want to use anything heavy or mechanical means as I had polished it up before the PC was applied. The Lacquer is a one I will get involved with again on another project
Post by GlennR on Jan 28, 2013 8:07:40 GMT
Nice one JB Did you get my e-mail?
Post by GlennR on Jan 28, 2013 10:30:23 GMT
Cheers JB
Post by norvin on Jan 28, 2013 14:40:55 GMT
John one photo of your engine shows the servo unit black and later gold, the gold one is on on my car, so have you a new servo and is the gold the correct colour.
Post by johnwp5bcoupe on Jan 28, 2013 15:44:05 GMT
John one photo of your engine shows the servo unit black and later gold, the gold one is on on my car, so have you a new servo and is the gold the correct colour. I did it black years ago norvin but didn't like it and no it isn't gold after a bit of research it was Cadmium plated as I didn't like the Passivated Zinc looked too modern, so I had it Coloured Zinc Coated as near to Cadmium as possible as the Cad process was banned
Post by johnwp5bcoupe on Jan 29, 2013 12:15:44 GMT
Getting slowed down the Exhaust Manifolds should have been here yesterday the "B" couriers haven't picked them up yet not bad for a 24hr service. Still Haven't picked them up 3 days don't use Parcel2go A bit more blog
Post by David on Jan 29, 2013 13:59:15 GMT
Speechless!
This has to be the definitive thread on setting a level for concourse. Well done John.
Post by GlennR on Jan 29, 2013 14:49:15 GMT
A table for two please
Post by johnwp5bcoupe on Jan 29, 2013 15:26:14 GMT
Thanks GB White or Red
Post by johnwp5bcoupe on Jan 29, 2013 15:28:50 GMT
Speechless! This has to be the definitive thread on setting a level for concourse. Well done John. Thanks David I am trying to do a good job getting too old to do it all again in 17 years time which is when the lump went in last
Post by eightofthem (Andy) on Jan 30, 2013 20:41:50 GMT
Looking very nice big j Bet you cant wait tofire it up. What clour are the manifolds going to be?
Post by johnwp5bcoupe on Jan 30, 2013 20:49:39 GMT
They will be Cast Iron colour Andy and they should be here in the morning following a co*k up by the courier I will take a picture before fitting
Post by johnwp5bcoupe on Jan 31, 2013 19:23:33 GMT
Post by barryr on Jan 31, 2013 23:48:34 GMT
Looking great!
Is this the new ceramic type coating that reduces under bonnet heat? It should last forever if so!
Post by enigmas on Feb 1, 2013 1:16:11 GMT
The coating is known as 'jet hot' in OZ and is very resonably priced. It's a great thermal barrier...unlike chrome...can be polished and can be applied to used headers ,etc after appropriate cleaning. It also increases component life considerably. I've used it for several motor cycle exhausts. It can also be used for many engine components subject to heat, erosion and contamination.
