Post by wozzer on Feb 21, 2018 22:51:58 GMT
Looking good. Did you have to change/modify the exhaust manifold because of the "new" steering shaft? Keep up the good work! Peter Not had the engine back in yet Peter but if my measurements are right then it should clear fine.
Post by wozzer on Mar 2, 2018 18:43:51 GMT
Front bags in and temp aired up
Post by enigmas on Mar 2, 2018 22:02:31 GMT
Looks really professional Wozza...very neat installation. I'm sure the ride will also be much improved.
As an aside...what is the viable suspension travel at 'normal' ride height...and is a bump stop required at maximum drop or compression. (Just wondering whether there could be any internal contact of the air bag components during maximum drop or compression under arduous driving situations,for example...traversing a large pot hole, rutted road surfaces, etc.)
Post by wozzer on Mar 5, 2018 19:27:18 GMT
Looks really professional Wozza...very neat installation. I'm sure the ride will also be much improved. As an aside...what is the viable suspension travel at 'normal' ride height...and is a bump stop required at maximum drop or compression. (Just wondering whether there could be any internal contact of the air bag components during maximum drop or compression under arduous driving situations,for example...traversing a large pot hole, rutted road surfaces, etc.) Hi Vince From fully closed to fully open is 5 inches, at this stage I don't know how much of that 5" will be useable at normal rideheight but I assume it should be at least 4". The air bags have an internal bump stop the same as a standard coilover shock .. Woz
Post by wozzer on Mar 10, 2018 21:05:07 GMT
Finally got to get the engine back in tempory for the first time in ages so I could check clearances around the new steering shaft for starter motor and exhaust headers. This pic shows just how much clearance there is. I have also marked the sump where it fouls the steering rack which is minimal but does need clearancing. The engine is now back out and starting to be stripped to check for wear and to get ready for painting. Woz
Post by notenoughtime on Mar 10, 2018 22:12:40 GMT
Great build this, nice to see it being brought into the 21st century
Post by petervdvelde on Mar 10, 2018 22:54:25 GMT
good to sea that there are no clearance issue's with the shaft
Post by wozzer on Mar 11, 2018 18:20:13 GMT
Sump modified today to gain a bit of clearance for the rack, pictures tell the story. More soon
Post by notenoughtime on Mar 11, 2018 20:08:00 GMT
Nicely done
Post by wozzer on Apr 14, 2018 20:36:50 GMT
Just a quick update to show that I've not been idle. Engine is painted and installed, I am now taking a few bits off of the engine for detailing and repainting, it won't be as original but clean and functional.
Post by notenoughtime on Apr 14, 2018 21:00:21 GMT
Coming along nicely when do you think it will be on the road?
Post by wozzer on May 4, 2018 19:32:13 GMT
Coming along nicely when do you think it will be on the road? Was hoping to have the outlaw coupe out this summer but this maybe wishful thinking. I've got most of the engine back together just waiting for the carb rebuild kits so I can test the motor. As I've said before the engine is not original but will be functional. Woz
Post by wozzer on May 7, 2018 7:19:07 GMT
Front end all finally fitted on the outlaw coupe, new braided brake lines are in and connected. Rear floors are now fully coated and the new brake lines and petrol lines are being fitted. Need to machine up the lower 4 bar spacers and then I can call the rear end done. W.
Post by Roy of the Rovers on May 9, 2018 13:05:55 GMT
Its going to be a shame to hide that gorgeous brake set up behind the new wheels! I'd definitely have to have a set of 5 spokes to show them off
Post by wozzer on May 9, 2018 21:23:30 GMT
Its going to be a shame to hide that gorgeous brake set up behind the new wheels! I'd definitely have to have a set of 5 spokes to show them off Yeah maybe a shame but it's all about the look Roy, plus I'll know their there lol
Post by wozzer on May 17, 2018 13:32:54 GMT
Carbs all cleaned, new gaskets, jets and needles
Post by wozzer on May 24, 2018 13:17:42 GMT
Made up the final part of the four bar rear, new spacers and bush insert to match the forward rear spring hanger. Cleaned up the fuel tank inside and out, cleaned the pre filter and blew through the fuel lines ready for fluids. W.
Post by wozzer on May 26, 2018 7:26:57 GMT
A little bit of bling for the engine bay of the outlaw coupe to replace the original cast ones that had damaged flanges. Obviously these are not a performance upgrade but pretty much a replacement with a bit more kerb appeal. W
Post by enigmas on May 26, 2018 8:15:10 GMT
A nice bit of bling Wozza...stainless steel? The only down side given the configuration is that your engine bay may sound like a MK2 Zephyr...if you recall the sound of the exhaust pulses and the reason for it.
Post by wozzer on May 26, 2018 18:04:36 GMT
A nice bit of bling Wozza...stainless steel? The only down side given the configuration is that your engine bay may sound like a MK2 Zephyr...if you recall the sound of the exhaust pulses and the reason for it. Yeah stainless Vince, be interesting to hear what they sound like, they're fitted now and I'm getting ready to fire the old girl up so it won't be long and I'll Know what sound they make.
Post by petervdvelde on May 27, 2018 21:07:42 GMT
Nice, always a milestone! Keep up the good work
Post by enigmas on May 27, 2018 23:00:39 GMT
Wozza...you mpa video file doesn't play unless it's downloaded. If you embed it somewhere like the video icon (URL) in the toolbar above your post or in Youtube or similar video hosting site, it'll play automatically.
Post by wozzer on May 27, 2018 23:47:27 GMT
Post by wozzer on Jun 8, 2018 21:10:46 GMT
Rebuilt radiator by Guildford radiators. A quick shout out for these guys, phoned up about the rad last friday same day collection four day turnaround and delivered back yesterday. Looks brand new, great job guys highly recommended. Also got a complete set of hoses from wadhams and all my new exhaust components also arrived.
Post by wozzer on Jun 10, 2018 22:05:04 GMT
Rad and new hoses installed. I've got to replace a couple of old hoses that I've installed that I forgot to get initially but I can do them whenever. Need some new breather hoses as well but all in all works great. Onto new exhaust system now.
